Artnet Unicast to avoid performance issues
  • Janson
    by Janson » Mon Feb 25, 2013 12:22 am
    I strongly need suport for unicast artnet. In other software like MADRIX, it is possible to set an ip adress for every fixture. I currently run into huge performance problems when sending more than one universe, because every artnet node has to process ALL artnet packets. That's really bad :(
    In MADRIX there is also a discovery feature via artnet poll.
    Re: Artnet Unicast to avoid performance issues
    by franz » Mon Feb 25, 2013 2:54 pm
    what artnet node are you using ?
    effectively, we are broadcasting artnet signal.
  • Janson
    by Janson » Sun Aug 04, 2013 4:55 pm
    I am using the DIY LED Stripe Project for Arduino. To save money we would like to use the Arduino Ethernet instead of Arduino Mega+Ethernet Shield for each stripe. The Arduino Ethernet has performance issues with broadcast because of its small amount of RAM.
    Really looking forward to Unicast :/
Users browsing this forum: Baidu [Spider] and 16 guests
