MacBook Pro Retina whit 3 video out
    shveddi
    by shveddi » Mon Feb 25, 2013 10:55 am
    Good afternoon.
    Updated the system itself to MacBook retina with 2 thunderbolt, and 1 hdmi
    MadMapper does not allow control of all three. only choice. Although they work very well without the MM. create one for them to work with both TripleHead2GO. to create panoramas
    I am from Belarus and I use a translator. Excuse me for any incorrectly translated.
    Sincerely Sergei!
    Re: MacBook Pro Retina whit 3 video out
    by ilan » Mon Feb 25, 2013 11:56 am
    MM does not yet support multiple hardware outputs. The 'un-supported' workaround is to duplicate the app several times and assign each instance to each output.
    shveddi
    by shveddi » Mon Feb 25, 2013 12:47 pm
    thanks
    In the future, MM?
    by ilan » Mon Feb 25, 2013 1:01 pm
    "... does not yet... " ;)
