Tunnel Mapping
  • CONTACT
    Tunnel Mapping
    by CONTACT » Sat Mar 02, 2013 11:28 pm
    Hey, was wondering if anyone had any experience with mapping a tunnel?
    Tunnel will be made of fabric. Using 3 short throw projectors on the outside of the tunnel, 1 on the left and right sides and 1 shooting from above. Triplehead2go system.
    Tested on a cylinder in modul8 using bezier curves and was successful in mapping, but As I will not be projecting from inside the tunnel, will I still be able to get the intended tunnel effect of light traveling from the front of the tunnel to the back?
    Hope that makes sense.
    Thanks in advance!
    NateMac
    Re: Tunnel Mapping
    by NateMac » Mon Mar 04, 2013 6:24 am
    I'm not sure if this is exactly answering your questions, it wasn't completely clean what you are trying to find out here...
    But, if I was doing a tunnel mapping I would still act as if the image was a flat image and just send a masked version of sections of the image to each projector. Just understanding the more of an image "height" you send to each projector, the harder it will be to blend. I beleive people are using a software called Blendy(http://www.blendy.in/) to help with this.
    I did some 3D Pre-viz you can see below how I would attempt this. Good luck and can't wait to see your results.
Users browsing this forum: Baidu [Spider] and 36 guests
