Edge blending
  • AgentD
    Edge blending
    by AgentD » Tue Mar 05, 2013 5:05 pm
    I'm going to do a long horizontal projection and planning on using 3 projectors. The last time I did something like this the edge blending with Madmapper/Modul8 was so complicated by using external png file etc I ended up switching to Resolume in the last minute. I personally prefer Modul8/Madmapper and wondering if there is any easier and quicker way to do the edge blending. Please let me know if you have any suggestions. Thanks a bunch in advance!!
    pele2010
    Re: Edge blending
    by pele2010 » Tue Mar 05, 2013 5:58 pm
    Hi ,
    have you tested "blendy" ?
    http://www.blendy.in/
    it´s a syphon app that makes edge blending easy .
    and did you read this thread ?
    http://forum.garagecube.com/viewtopic.php?f=3&t=4771&p=23188&hilit=edge+blend#p23188
    But: I did not check the latency on this.
    hop this helps you ...
    and i think i read that their is a Quartz composer composition for this purpose.
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • AgentD
    Re: Edge blending
    by AgentD » Tue Mar 05, 2013 6:36 pm
    Thank you for the suggestion. I checked out Blendy and it looks good. I was hoping that there is a way to do that with the existing tools within Madmapper or Madul8.
    pele2010
    Re: Edge blending
    by pele2010 » Tue Mar 05, 2013 7:03 pm
    http://forum.garagecube.com/viewtopic.php?f=29&t=8087
    that´s what garagecube says.
    and you can do it within Modul8 but it´s not plug and play.
    here´s a tutorial for that too:
    http://www.youtube.com/watch?v=6Wt1GmOopVo
    i´m not sure if this Tut was posted in the previous thread.
    Edge Blending used to be an "Art" before there where computer.
    And it´s still a Job on it´s own.
    I usually let this to an technician.
    hope this helps
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • sir.phit
    Re: Edge blending
    by sir.phit » Thu Mar 10, 2016 1:00 am
    maybe i'm cheap, or old school, or maybe i'm just lazy... but i tend to take a roll of masking tape and then put a piece so it covers one edge of the projectors len(example left side of lens) ever so slightly in order to soften the edge then do the same on the other projector(right side) so they line up together with the softened edges so as to create a soft edge blend on the screen... also i make sure there's a bit of over lap in my slices so its the same part of the video getting softened on both projectors(or more if i'm running more then two together)
    VjKg
    Re: Edge blending
    by VjKg » Sat May 28, 2016 6:22 am
    MadMapper has had this function for over a year.
