Madmapper + Kinect + Modul8
  • carolr
    by carolr » Thu Mar 07, 2013 9:14 am
    Hello, I'm pretty much new to video mapping software, but I'd like to know:
    Is it possible to apply the Mad Kinect Mask on MadMapper over a video input from Modul8 through Mad Doubler? Or does the mask only work with the Mad Apps (like the Mad Graphic Patterns, for example)? I'm a bit confused so if you could explain it simply I'd appreciate it. I know that the Mad Doubler supports Syphon apps, but is it only possible to apply the mask inside the body outline through Modul8?
  • carolr
    Re: Madmapper + Kinect + Modul8
    by carolr » Thu Mar 07, 2013 9:33 am
    Edit: I've tried it and the Modul8 video input works but only in the background and not inside the outlining of the Kinect image. Help?
    by franz » Thu Mar 07, 2013 8:02 pm
    yes,
    you can use MAD_Doubler to concatenate M8's output and MAD_Kinect output together into a single Syphon texture,
    that you would receive in MadMapper's input.
    Depending on your computer, performance might be harmed a little bit tho'.
