Transformer Patch crappy via Syphon
    txo!?
    by txo!? » Fri Mar 08, 2013 8:29 pm
    Hello there
    I´m not able to take a smooth output of the Trasnformer Pacth via Syphon.
    Look at the images below, as you can see there is a notable diference betwen modul8 and syphon.
    Some facts:
    -In those example I'm working on 1280x720px. (modul8's syphon output size, modul8's advanced output size and syphon recorder size)
    -If I record it with the syphon recorder (any codec) it looks same, bad.
    -If I render to disk with modul8 it looks great.
    -output to a external proyector is ok.
    -output to via syphon (siphon recorder, madmapper, quartz composer) is crappy.
    -It is the same if I put another layer as background or leave with the modul8 background.
    It looks that it is not apllying the antialising or something...
    Anyone some idea about this?
    *edit: oups the spects
    Modul8 2.6.2
    MacOs 10.6.8
    2.66 Ghz Intel Core 2 Duo
    8Gb RAM
    NVIDIA GeForce 9600M GT: VRAM 256 MB
    thanks
    pele2010
    Re: Transformer Patch crappy via Syphon
    by pele2010 » Fri Mar 08, 2013 8:54 pm
    Hi ,
    is antialiasing in the preferences menu set to "None"
    i made a quick check with a stroke from the paint module and the
    snapshot from syphon recorder looks perfect.
    i can´t reproduce the low quality output. .
    even when i set low quality , the syphon output looks good.
    keep in mind that you need to reastart after changing the prefs to "none"
    i hope this helps .
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    txo!?
    by txo!? » Fri Mar 08, 2013 9:07 pm
    hello pele
    The antialiaing preferences is set to high (and it happens with the lower options also)
    If I had the antilaising pref. to none it would be crappy on the modul8 preview panel also :)
    I have not problem at all with the paint module neither,
    it is only with the transformer, any other thing looks good :(
    thanks
    pele2010
    by pele2010 » Fri Mar 08, 2013 9:20 pm
    I checked it with transformer "matrix"
    which one did you use ? "patch" ?
    And i checked again "none" looks good in MD8 and syphon
    have you passed this to the support ?
    have you checked a newer version of MD8 ? 2.6.4 or 2.6.7 (beta)
    you can download this version from the "yourspace" server
    hope this helps .
    #eachfilm01
    #pele2010
    www.eachfilm.de
    txo!?
    by txo!? » Fri Mar 08, 2013 9:28 pm
    hi there
    I used pacth and I wanted in "high", at least other than none to have smooth edges :)
    Is it ok for you using antialiasing high? (or other than none)?
    I didn't pass it to support, I was trying here first :wink:
    I'll try with a newer version
    thanks for your help!
    pele2010
    by pele2010 » Fri Mar 08, 2013 9:55 pm
    ok,
    i used patch - shape "square" and then i tested
    grid , dots and plain ....
    prefs set to "high"
    and i pushed up and down the thickness.
    I definitely can reproduce the posted phenomenon.
    - smooth edges in preview panel / rough edges in syphon output.
    why do we see those edges in "none"?
    thnaxs for posting.
    did you check the projection too ?
    #eachfilm01
    #pele2010
    www.eachfilm.de
    txo!?
    by txo!? » Fri Mar 08, 2013 11:57 pm
    Ok
    thank you
    So it is not just me :)
    I tried with 2.6.5 and same thing happen.
    I'll give it couple of days here and go to support
    I'll post whatever I get :)
    pele2010
    by pele2010 » Sat Mar 09, 2013 12:15 am
    HI ,
    maybe it´s a good to post it at the syphon forum ?
    http://syphon.v002.info/
    or ask vade if he can help ?
    hope this helps too.
    #eachfilm01
    #pele2010
    www.eachfilm.de
    david
    by david » Mon Mar 11, 2013 10:15 am
    No, it is not just you. Syphon output is not anti-aliased. This will be corrected in a future release.
    Regards.
    txo!?
    by txo!? » Mon Mar 11, 2013 10:55 am
    Thank you David
    Now I know it is not a bug neither something wrong I was doing.
    I'll be waiting solicitous :)
    txo!?
    by txo!? » Fri Mar 15, 2013 6:55 pm
    Hi there
    just to show why I wanted to be able to output the trasnformer stuff vía syphon with antialias: https://vimeo.com/61665351
    :D
