Mask Points Double when deleted
  • drosen
    by drosen » Thu Mar 21, 2013 11:37 pm
    Hi, I am experiencing an issue with mask editing on 1.4.2.
    When I delete a point from a mask, the next time I attempt to edit the mask, the total number of points doubles. These new points are in the same location as the previous points, but do not seem to control the mask. (they are free floating.). In a complicated mask, this makes the mask extremely difficult to edit. the false points may disappear after quitting and re-opening the file.
    -drosen
    doubled mask points
    Re: Mask Points Double when deleted
    by ilan » Fri Mar 22, 2013 10:31 am
    Hi Drosen,
    Tested this out and you are correct. I will report this to our dev team immediately.
  • drosen
    by drosen » Sun Mar 24, 2013 9:31 am
    thanks!
    good to know it is replicable.
