Enttec dmx usb pro not found
  • menoTV
    by menoTV » Sun Mar 31, 2013 12:21 am
    Installed both drivers, the ones on enttec site and fro the FTDI site.
    usb pro utility connects to the pro fine and i am outputting DMX using that.
    When i select usb pro in MM for my dmx output there is nothing in the dropdown menu for madmapper interface.
    Do the drivers support 10.8? the file its in only mentions 10.5-10.7. Is that the problem? -is 10.,8 not supported?
    Thanks
    Re: Enttec dmx usb pro not found
    by franz » Tue Apr 02, 2013 11:41 am
    are you using the MKII version or the original ?
    if using the MKII, please try to install the original drivers (v1) and see how it goes.
    We've tryied successfully the Entec USB DMX Pro MKII at the office using the latest FTDI drivers, and it was working nicely.
    It was under 10.6.8 tho', so unfortunately I can't provide any info on 10.8. We'll look into this issue ASAP.
    Please contact the support if the problem persists.
  • menoTV
    by menoTV » Tue Apr 02, 2013 10:54 pm
    Hi Franz hanks for the reply.
    No it's an original? does it only work with the MKII??
    Thanks,
    Justin
    by franz » Tue Apr 02, 2013 11:21 pm
    it should work with the original as well.
    try the following:
    -unplug everything
    -plug the enttec
    -launch madmapper
    -go to preferences / DMX Output
    -select protocol DMX usb pro
    -your card should now be listed on the right list (MadMapper interface)
    -select your card and close the preferences
  • menoTV
    by menoTV » Wed Apr 03, 2013 1:24 am
    Still nothing.
    I will try tomorrow with a machine running an older version of osx...
    by franz » Wed Apr 03, 2013 4:50 pm
    just to be sure, do you have MM 1.4.2 ?
    any prior version is likely not to work
  • menoTV
    by menoTV » Thu Apr 04, 2013 12:12 pm
    Yes 1.4.2 and tried a fresh install as well.
  • menoTV
    by menoTV » Thu Apr 04, 2013 12:15 pm
    Just so i can rule out possibilities.... if the drivers had not been installed properly for some reason, would the pro utility still work? presumably it wouldn't. ??
  • menoTV
    by menoTV » Fri Apr 05, 2013 5:01 pm
    Works fine on my partner's MBP running 10.6
    confused.
    by franz » Sat Apr 06, 2013 6:42 pm
    driver problem then.
    clean up everything and restart the driver installation process.
    Favor the latest FDTI driver first (get it from their site), then eventually switch to the Enttec one (remove the other first) if things go wrong.
    david
    by david » Tue Apr 09, 2013 10:09 am
    Hi all,
    take a look at my answer on how to test DMX USB Pro installation : viewtopic.php?f=3&t=8612&p=25755#p25755
    Regards
