Projector recommendation
  • plazadelmar
    by plazadelmar » Mon Apr 01, 2013 6:00 pm
    Hey guys,
    I'm new to mapping and I'm about to invest in a new projector. There is a jungle out there so I would like to ask for your help and for recommendation. I'm about to start small scale mapping projects such as mapping on toys, boxes etc where I want to learn and make all the small mistakes :)
    Is LED to recommend or would you invest in DLP or LCD? What about ANSI, are the small LED with 100-200 ANSI enough to start with? Is resolution such as 1280 x 800 WXGA enough?
    All your advice will help me to make better decision and in advance I thank you for your help.
    Here is example of what i have in my mind.
    https://vimeo.com/15860939
    //Dom
    NateMac
    Re: Projector recommendation
    by NateMac » Tue Apr 02, 2013 3:44 am
    I think the unfortunate question that really is going to make your decision for you; what's your budget?
  • plazadelmar
    by plazadelmar » Tue Apr 02, 2013 7:30 am
    To start 300€
    by ilan » Tue Apr 02, 2013 2:21 pm
    If you spend a bit more the Dell m100 is a nice one. An Acer k11 that is no longer in production might be purchasable via ebay or in remaining stocks.
    NateMac
    by NateMac » Tue Apr 02, 2013 4:14 pm
    If that was my situation, IMO I would go way under budget with a Pico Projector, and use that time practicing with a low end projector to save up for something that can hold it's own a little better. The Optoma HD230X Full HD 1080p Home Cinema Projector is £670 on Amazon UK. This way your not without anything, but also can spending a little more later on something that could have a useful purpose then just to "play" with.
  • plazadelmar
    by plazadelmar » Tue Apr 02, 2013 4:16 pm
    Should I go for "short throw"?
    I also heard LCD is best choice for mapping. What you think?
    What is pros and cons with LED projector?
    NateMac
    by NateMac » Tue Apr 02, 2013 6:14 pm
    LED sub $10,000 are low light. above $10,000 might be worth looking into LED light source.
    i.e. Acer K130 sub $500 LED Projector: 300 Lumens
    Acer H5350 about $600 Lamp Projector: 2,000 Lumens
  • plazadelmar
    by plazadelmar » Tue Apr 02, 2013 7:19 pm
    Here is swedish located company with great assortment and prices.
    http://www.projektorshop24.se/projektor ... /1/36.html
  • jmckeehen
    by jmckeehen » Sun Jan 17, 2016 10:00 pm
    I've been having a ton of success/fun prototyping with the rif6 cube. If you want something extremely portable for small installations, this one is great. Comes in under your budget, is 2" x 2" x "2 and maps well. Since you're starting small, thought I'd recommend this one from personal experience.
