Change madmapper of a new Macbook
  • flaechenbrand@web.de
    by flaechenbrand@web.de » Thu Apr 11, 2013 8:47 pm
    I want to change my macbook and my Machines authorized: 2 (out of 2) .How can I change my license to a new macbook?? :cry: :cry:
    Re: Change madmapper of a new Macbook
    by ilan » Fri Apr 12, 2013 10:43 am
    Please contact us at support [at] garagecube [dot] com so we can assist you.
    by franz » Sat Apr 13, 2013 5:09 pm
    Launch MadMApper on your old machines, then go in the MadMApper menu section,
    and while connected to the internet, de-authorize MadMapper.
    Once de-authorized, you can authorize the app on new machines.
    Forgetting to do so wil drive your through the support, and take you some more time (needed to verify and process your request)
  • timabad
    by timabad » Fri Jun 21, 2013 11:47 pm
    Hi! I deauthorized madmapper from my older laptop and would like to add it to my new laptop. I tried emailing support@garagecube.com, and I haven't gotten a reply in over 2 days. I have a show tonight and really need the help. Is the garagecube email working right now?
    Thank you,
    Tim
    pele2010
    by pele2010 » Sat Jun 22, 2013 12:57 am
    Hi, you don´t need the support for de-authorize!
    You only need a working network.
    When you de-authorize your old macbook, you are able to authorize your new macbook.
    support(at)garagecube(dot)com should work perfectly. never had a problem with the support.
    hope this helps you.
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • walidvb
    by walidvb » Mon Mar 09, 2015 12:24 am
    Also, if you don't have access to the machine anymore, you can remotely reset it in your yourspace page.
    Be aware that you will be able to reset each licence one time, after which you will have to wait one year before using the remote reset again.
