1:1 Copy of Slices between both Input to Output
    lotech
    by lotech » Sun Apr 14, 2013 11:36 pm
    When I'm setting up a mapped structure I often am basing it off a picture or plan view as a result I've often done most of the mapping off site.
    As a result MadMapper helps us clean up the map on site (and use presets to vary it as necessary) but a lot of the work is in having to draw each surface TWICE - once in the input and once in the output. This can mean that 1:1 mappings aren't quite 1:1 as I have to draw the output box from scratch and chances of it being pixel accurate is very slim.
    It would be great if there was a setting to enable that would 'sync surfaces between input/output' so while its enabled if I draw a surface on the input - it draws the exact same surface on the output. Then once the majority of the map is done I can disable it and tweak the output surfaces so they work in the real world.
    I'm sure I'm not the only who would find this feature extremely useful.
    Re: 1:1 Copy of Slices between both Input to Output
    by franz » Mon Apr 15, 2013 11:02 am
    that's a good idea.
    by ilan » Mon Apr 15, 2013 8:26 pm
    'Sync surfaces' would be a good simple name for that.
  • tomtooms
    by tomtooms » Mon Apr 28, 2014 9:34 pm
    yes definitly !
    this could make us saving hours !
    thanks
