DL-3 Projectors support with MadMapper
  • sk8ermarc
    by sk8ermarc » Tue Apr 23, 2013 4:43 pm
    I have a new project coming and I will need to use a DL-3 projector from Highend Systems, but I never worked with one before.
    I've done some research on the compatibility with MadMapper but I couldn't find anything on the subject.
    Anyone here has some experience with these projectors and would like to tell me if they can be connected with MadMapper on a mac?
    I know you should need the Content Management Application software they have on Windows only to connect to the projector, but will it work with a DMX ethernet directly on a mac?
    Thanks for your time!
    Re: DL-3 Projectors support with MadMapper
    by franz » Tue Apr 23, 2013 6:11 pm
    AFAIK, DL3 can be controlled by DMX signals, as can MadMapper.
    You could have some DMX data triggering - at the same time - DL3 positions and MadMapper presets, for instance.
Users browsing this forum: Baidu [Spider] and 25 guests
