PathEditorPLSAutomation
  • Jeremy Cooper
    by Jeremy Cooper » Tue May 07, 2013 7:50 pm
    Hey guys, I hacked together code from a couple modules to include some different functionality to the MotionPath Module. I based it all off of PLS's blur edit (viewtopic.php?f=12&t=3672) and used code from BPM Router to get the rest working. It can be found in the online library.
    Use "pick" to select a control to automate (hold down "show all" to see the full text of the control), and change the desired control value of each point by first selecting the one you want to edit and moving the "SEL AMOUNT" slider, also you can toggle the "FINE TUNE" button to more accurately assign your value. Then just make sure you turn Automation on and press play!
    Hope you guys like it, it was definitely a learning experience for me, going through Yves's code and piecing together how it worked was a real treat.
