HELP: How to use a clip as an Alpha to a layer?
  • Push1stop
    by Push1stop » Sun May 12, 2013 5:42 pm
    Hello! I am wondering if there is a module who exist that allows me to use a clip in the mediaset as an alpha to my layer or my global, at least? I know the modul "mask" but it is just a layer on top of my other layers. I want to be able to take another clip and use is as an alpha: simple compositing!
    EX. 3 CLIPS
    1- dog
    2- bone
    3- Flower
    The bone is use as an alpha to the dog so it creates a hole in the dog and we can see the layer under: the flower.
    Thank you it's been years since I want a module like this but I am not geek enough to code it.
    pele2010
    Re: HELP: How to use a clip as an Alpha to a layer?
    by pele2010 » Fri May 31, 2013 5:25 pm
    here is a Tutorial how to use the Alpha of a Layer
    http://www.youtube.com/watch?v=iDyxDRkjiVc
    To use the Alpha , the Picture need the Alpha information.
    If not: YOu could use the Luma Information as Alpha.
    YOu would do this under the pixel Fx Menu and use a LUMA KEY .
    You could also do this with the Blending Modes.
    I hope this helps you ....
    _____________________________________________________________
    The best Format is ".png" with Alpha.
    In Photoshop you can save the Picture with the Alpha information ....
    If it´s an Animation you can export this from After Effects as a Quicktime / Format "png" with Alpha information.
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    pele2010
    by pele2010 » Fri May 31, 2013 5:27 pm
    Have you tested to "sub" the bone ?
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • Push1stop
    by Push1stop » Mon Jan 06, 2014 11:02 pm
    Thank you, this is not really what I wanted to do, but the new version of Modul8 as finaly new blending modes so it solves my problem!
  • darlaflick
    by darlaflick » Thu Sep 18, 2014 11:06 am
    You won't be able to do that. OSC is not natively implemented into modul8… but you can do that very easily with madmapper now! give it a try :)
