See output window on external monitor AND laptop monitor?
  • helen888
    by helen888 » Thu May 23, 2013 2:12 am
    I'm trying out the demo of Modul8 and am loving the possibilities!
    The only issue I'm having is that for the performance I want to do, my back will be to the screen.
    Is it at all possible to place the output window full screen on a second monitor (the one behind me), but to also have a smaller copy of the output window on my laptop monitor, so that I can see what the audience is seeing as I manipulate controls inside of Modul8?
    If this isn't possible, I'd be working blind and obviously it wouldn't be effective. :(
    Can something like this be done? Thank you so much for your help!
    Re: See output window on external monitor AND laptop monitor
    by ilan » Thu May 23, 2013 4:46 am
    You can do this using the Advanced Output.
    See page 84 of the documentation. But instead of following the tutorial in making 3 outputs make only 2 and make sure that the two 'clips' you create overlap each other.
    - Assign 1 'clip' to 'Output Main'
    - Assign the other to 'Output 2'
    Now when you enable full screen your main monitor and the output will display the same image.
  • shentoy
    by shentoy » Wed Jun 12, 2013 1:51 pm
    I had started working with Modul8 some time back, but I was not successful in creating this external window. I would like you to know how you are going on with your work and anyone who can help regarding this problem.
