MadMapper 1.5 beta 1
    by franz » Tue Jun 11, 2013 4:31 pm
    today we released MadMapper 1.5 beta 1 !
    This beta is available to all registered users. Don't use it for production !
    Download it from www.madmapper.com/yourspace as usual.
    What's new:
    - Multi output support via a dedicated Projector Panel
    - built-in Live Video Input (tested with a blackMagic card)
    - MAD_Line built in, with the new Line Primitive
    - Enhanced Help menu
    - numerous bug fixes and improvements
    Report any bugs to the support or on this thread.
    Thanks / MadMapper team
  • tony_blend
    Re: MadMapper 1.5 beta 1
    by tony_blend » Tue Jun 11, 2013 5:43 pm
    Loving the madline integration.
    Fragmentia: A relatively new cognitive disorder where one feels cut off from a sense of wholeness because of constant exposure to only incomplete parts of things and ideas which do not
  • tony_blend
    by tony_blend » Tue Jun 25, 2013 6:45 pm
    Projector panel works like a charm as well!
  • eMTv
    by eMTv » Wed Jul 31, 2013 1:12 pm
    Hi Franz,
    in the projector panel, although I have 3 output projectors connected to the triplehead, Madmapper seem to only detect 2 ? (see attached screenshot)
    - I'm using the projectors vertically, so the general output resolution is 600*2400 (instead of 2400*600) -
    thanks in advance for your help.
    Capture d’écran 2013-07-31 à 13.08.07.png (14.29 KiB) Viewed 6898 times
    by franz » Wed Aug 28, 2013 12:52 pm
    MadMapper detected aDualHead, not a TripleHead.
    Did you install the latest drivers from Matrox ?
    Does it work without MadMapper launched ? (with 3 screens connected)
