Artnet Universes
  • howie_b
    Artnet Universes
    by howie_b » Sun Jun 16, 2013 4:27 pm
    Having a go at using MM to control LED fixtues - in combination with a Chamsys MagicQ lighting desk.
    All the MM fixtures are set to the same universe - but it would seam data is being sent to all artnet universes.
    Which is causing data colissions with artnet being sent on other universes from the magic Q.
    Is it possible to restrict MM to only output to universe that contain fixtures - leaving other universes alone for others to play with...
    Hope this makes sense- i can provide more detail of the setup if need be.
    howie
  • howie_b
    Re: Artnet Universes
    by howie_b » Sun Jun 16, 2013 4:50 pm
    good news - further testing and it looks like this is only an issue in the latest beta- MadMapper_1.5.2326_BETA
    tried MadMapper_1.4.4.2328 and all worked as expected.
    looks like i need 1.5 release :-)
