copy only one parameter from layer to layer ?
    pele2010
    by pele2010 » Wed Jun 19, 2013 9:24 am
    i am stuck with this problem. How can i copy just the "speed" or the "scale" from one layer
    to another?
    I only came up with the solution of duping it and then cero the parameters you don´t need.
    Thanxs pele
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • anomad
    Re: copy only one parameter from layer to layer ?
    by anomad » Wed Jun 19, 2013 7:11 pm
    . the most configurable option would be to write your own module to allow you to pick and choose which parameters from which layer would be applied to another layer...
    . you can use the Modules->Keyword Browser (and the click the 'Pick In interface' button to determine the name of the element, like
    ctrl_layer_movie_speedFactor
    . then to get the value :
    mySpeed = modul8.getValue('ctrl_layer_movie_speedFactor', 0)
    . 0 for currently active layer, or you can hardcode the layer if it will always be the same or create a UI element in your module to choose the 'from' and 'to' layers dynamically. the set the value:
    modul8.setValue('ctrl_layer_movie_speedFactor', mySpeed, 2 )
    . the '2' being layer 2 - but set that to the layer you want to change. check out the Modul8 online manual for more information about getting and setting values.
    . good luck! :)
    -james
    (a nomad. )
    pele2010
    by pele2010 » Wed Jun 19, 2013 8:56 pm
    Hi James,
    thanxs
    i´ll give it a try.
    pele 2010
    #eachfilm01
    #pele2010
    www.eachfilm.de
