Globally setting a channel value for fixture set.
  • octopoda
    by octopoda » Thu Jun 27, 2013 1:58 am
    It would be incredibly helpful to be able to manually assign a value to a channel across a set of fixture(s). I.E. I have a number of traditional LED par cans that I'd like to use as large pixels. However, in order for the RGB to work properly, the dimmer channel (in this instance 7) has to be set to 255. It would also be helpful if the amount of channels per fixture could be specified and then just toggle which channel is the RGBWL etc.
    Apologies if I overlooked a way to do this.
    Re: Globally setting a channel value for fixture set.
    by franz » Thu Jun 27, 2013 5:32 pm
    this is planned for an upcoming version of MAdMapper.
    We're currently working on it.
