ONE Enttec Controller for Modul8 & Madmapper?
    sehrinde17
    by sehrinde17 » Tue Aug 13, 2013 12:31 am
    Hey Guys!
    I bought two very cheap varytec led rotobars. i tested different madmapper dmx-fixtures. Now i think, i need the possibility to control the first three channels (1. Tilt 2. Strobe 3. Dimm) separate in modul8 via simple fader. The other channels i control in madmapper (5.- ... Color).
    Could some body tell me, if it´s possible to use ONE Enttec USB/ Artnet Donggle on ONE Mac in TWO programs? I want to control DIFFRENT DMX Channels through modul8 + madmapper.
    maybe somebody has a solution for me! :lol: Thanks!
    MacBook Pro Retina, Mid 2012
    2,3 GHz Intel i7 | 8 GB Ram | NVIDIA GeForce GT 650M 1024 MB | 250 GB SSD
    OS X 10.9.1
    Mac Pro Early 2009
    2x 2,26 GHz Intel Xeon | 24 GB Ram | NVIDIA GeForce GT 120 512 MB | 2x 2 TB SATA
    OS X 10.9.1
    Re: ONE Enttec Controller for Modul8 & Madmapper?
    by sigmasix » Tue Aug 13, 2013 10:38 am
    Both modul8 and madmapper send all the values of one universe so if you use both at the same time, they will step on each other with zeros…
    You could use an enttec ode with a plugin that gets only the highest values. Not sure it will work though.
    sehrinde17
    by sehrinde17 » Tue Aug 13, 2013 1:03 pm
    Thanks! I´ll try it!
    OS X 10.9.1
    Mac Pro Early 2009
    OS X 10.9.1
