"Add a Mask"
    johncgaiser
    "Add a Mask"
    by johncgaiser » Fri Aug 16, 2013 2:28 am
    Since there is no documentation,
    I need an explanation on "add a mask".
    I have added a mask and drawn in the area to mask. It does not seem to do anything at all. What am I doing wrong?
    What is this feature for and how do I use it?
    Thanks.
    Re: "Add a Mask"
    by franz » Wed Aug 28, 2013 12:49 pm
    you can:
    1- use the Mask primitive to make a mask and place it where you want in your layer stack
    2- create a quad and link a mask to it. There's a Mask thick box in the quad surface inspector that allows you to do this.
    johncgaiser
    Re: "Add a Mask"
    by johncgaiser » Wed Aug 28, 2013 3:51 pm
    Thank you so much for responding :)
