MIDI not working with Oxygen 61 on Mac
  • kdobbe
    by kdobbe » Mon Aug 26, 2013 7:15 pm
    I am running Modul8 2.7 on a Mac running OS 10.8. I am unable to use the MIDI map function via an M-Audio Oxygen-61. All other programs are receiving MIDI from this device, Modul8 is not. I have gone to preferences to make sure the M-Audio keyboard is checked.
    Please advise... I am anxious to be able to use the key mapping.
    Kevin
  • anomad
    Re: MIDI not working with Oxygen 61 on Mac
    by anomad » Mon Aug 26, 2013 9:09 pm
    . make sure to have the keyboard plugged in before starting Modul8
    . once Modul8 is running, go to 'Preferences' then click 'Key/MIDI Maping' - do you see the Oxygen in the list ?
    -james
    (a nomad. )
  • kdobbe
    by kdobbe » Thu Aug 29, 2013 4:02 pm
    I have tried that, and still no interaction. It used to work when I had an earlier version of Mac OS. Can anyone else confirm issues with MIDI in OS X 10.8.4?
  • kdobbe
    by kdobbe » Thu Aug 29, 2013 4:04 pm
    Problem solved.... bad cable. Thanks for the reply.
