1.5.1 Crashing with Multiple Outputs
  • infectedspleen
    by infectedspleen » Fri Aug 30, 2013 12:17 am
    Hi all,
    Just wondering if anyone has tried the multiple outputs feature with more than one TH2GO etc etc.
    I have a Mac Pro 4.1 with three NVIDIA GeForce GT 120 installed and i'm trying to run 9 projectors. The first gfx card has my monitor plugged into the dvi port and a projector plugged into the mini DP, I have a TH2Go analog edition plugged in to the dvi on the second gfx card and another projector plugged into the second mini DP and finally I have a TH2Go digital edition plugged into the third gfx card with another projector plugged into the mini DP.
    Every time I load MM it crashes on startup. Ive sent over a few crash logs when MM has asked me. Has anyone else tried running a similar setup.
    So far through trial and error I've managed to run one TH2Go or two mini DP or two mini DP and a TH2Go with out MM crashing. Ive tested the same setup in Resolume arena with successful results, All nine projectors playing clips.
    Ive also found that when using Mad_light with 1.5.1, it does produce some wired results and does not work well like it does with 1.4.4.
    Any help would be great.
    Re: 1.5.1 Crashing with Multiple Outputs
    by franz » Fri Aug 30, 2013 12:03 pm
    1-
    GT120 are very old cards (maybe 7 years old)
    Ideally, with 4 cards,
    you'll use one for monitor (on the 4x PCI-e port), and 3x TH2G miniDP on the remaining cards.
    2-
    Please contact the support regarding your crash, they'll help you
    3-
    What do you mean by weird results ?
    Are you using MAD_Light with GT120 ?
  • infectedspleen
    by infectedspleen » Fri Aug 30, 2013 1:16 pm
    Thank you Franz,
    I've sent over an email with my problems inc Mad_light to support.
    Hope they can help..
