fullscreen only on laptop
  • soupvisuals
    by soupvisuals » Sat Aug 31, 2013 12:30 am
    for some reason suddenly on both my mackbook pro's when i fullscreen mad mapper it refuses to go to the projector screens but instead full screen the macbook's monitor. this is trying to use a tripplehead as a dualhead with resolution at 2048 x 768, which is whn the problem started.
    Re: fullscreen only on laptop
    by franz » Mon Sep 02, 2013 7:31 pm
    did you configure the output projector correctly via the output tab ?
    Sometimes if you hot-plug/unplug a projector, MM 1.5.1 *might* loose its config.
    (should be fixed in 1.5.2)
    Does it also happen after a MM relaunch ?
  • hdprojections
    by hdprojections » Wed Oct 23, 2013 3:44 am
    Hello friends,
    NEED HELP! I have the same problem, I just got a Macbook Pro retina and downloaded MM, but something weird happened after the second test. First test it worked fine, I got to map my room for the test and all worked OK; In the second test I used two projectors to test MM and when I changed the input to the other projector it happened, now I only see fullscreen on my laptop! then I tried to fix this by changing the resolution on both computer and MM but no luck, I restarted MM and my Mac but not luck! could somebody please help me to fix this problem. Thanks.
    Will
  • soupvisuals
    by soupvisuals » Thu Oct 24, 2013 7:12 am
    still having this issue, any thoughts?
  • soupvisuals
    by soupvisuals » Thu Oct 24, 2013 7:21 am
    this is with madmapper 1.5.2
    when i load it up normally the back screen(s) go black automatically, this is not happening.
    I don't really care about the extra projector options unless that's screwing something up? i always made my shows works fine before that
  • soupvisuals
    by soupvisuals » Thu Oct 24, 2013 7:22 am
    by franz » Thu Oct 24, 2013 12:53 pm
    maybe your output is set to the main displpay (laptop)
    go to the output/projector tab, select your output and set it to your prefferred projector (normally appearing in the list, if a display is connected)
