Two times 1280x720px 32:9 in Preview Window
  • te-c
    by te-c » Tue Sep 03, 2013 5:29 pm
    I've got a strange problem in Preview Window.
    I want to have two clips (each 1280x720px in 16:9) side by side. I set up the Preview Window to 32:9 and the Syphon Output and all other Outputs to 2560x720px.
    If I set up two layers one left and one right and scale them from top to the bottom of the Preview Window they are not filling out the complete Window. I have to place them very accurate without loosing anything of the layers.
    In 4:3 ratios there was no problem in the past. For the next show I need two of them in 16:9.
    How can I fix this problem?
    I know I can change the size of the frames in madmapper but what's going wrong in modul8? Is it only optimized for 4:3 ratios?
    deepvisual
    Re: Two times 1280x720px 32:9 in Preview Window
    by deepvisual » Tue Sep 03, 2013 7:13 pm
    I think this is done by using the number value for scale instead of the slider..
    click/drag on the number - you may need to switch normalise off or on ( can't remember)
  • te-c
    by te-c » Tue Sep 03, 2013 9:03 pm
    That doesn't work. I've tried it. I think the size of the Preview Window isn't really 16:9 or 32:9.
  • te-c
    by te-c » Thu Sep 05, 2013 10:51 am
    I've tried it with normalize and without, with different scaling, with Transformation on reset and between minimum and the middle of transformation ratio.
    16:9 isn't 16:9 the same is for 32:9.
    I only can resize it in madmapper but then the piexls are not 1280x720 for each.
    Can anybody reommend this? anybody who have the same problem to display 16:9 in modul8?
    In this example I used v2.8 alpha, but it's the same in 2.7.
    Here are some screenshots:
