media with correct resolution too big for fullscreen
  • marlogue
    by marlogue » Fri Oct 18, 2013 12:00 am
    I have modul8 outputting to an external monitor of resolution 1024 * 768
    In modul8, I have my bottom layer with video-clips (from a DVD with black letterboxing), res 720*576, scaled up (not normalized) so that it fits the output frame without letterboxing visible.
    Above this layer I have a motion-graphics layer, created in After Effects at res 1024*768.
    When its scale is at 100% (RESET and at 2x) and normalize off, it is too large for the screen.
    When normalize is ON, it almost fits the screen but for being ever so slightly smaller than fullscreen (1 pixel less on all sides). This means I cannot composite these motion-graphics onto the videos without this annoying strip all around them where the video below is visible.
    WHY OH WHY IS MODUL8 NOT RESPECTING THE RES OF THE MEDIA which in this case is the same as the output resolution?
    sehrinde17
    Re: media with correct resolution too big for fullscreen
    by sehrinde17 » Tue Oct 22, 2013 9:30 pm
    hello!
    the size of my videos are 3072x768 pixel. after importing the clip the video is too big! or the modul8´s video output is to small (1920x480). but in the Prefs i have chosen the resolution i need for my clips. I have to Normalize and scale to Max to have the result i want.
    very strange...
    MacBook Pro Retina, Mid 2012
    2,3 GHz Intel i7 | 8 GB Ram | NVIDIA GeForce GT 650M 1024 MB | 250 GB SSD
    OS X 10.9.1
    Mac Pro Early 2009
    2x 2,26 GHz Intel Xeon | 24 GB Ram | NVIDIA GeForce GT 120 512 MB | 2x 2 TB SATA
    OS X 10.9.1
    by vanakaru » Thu Oct 24, 2013 9:51 pm
    While this is annoying indeed you may want to consider producing the media all same size and match your projector native size. Thus avoiding scaling here and there and most likely degrading the output quality.
    by sigmasix » Fri Oct 25, 2013 10:45 am
    Modul8 has a virtual stage that has a preview size of 640x480 bananas… If your media is too big, it will be croped but you can scale it down and once you go fullscreen it will get all its pixels back. The scaling down operation is a difficult one actually, sometimes the "normalize" button doesn't produce what you would expect…
    sehrinde17
    by sehrinde17 » Thu Nov 07, 2013 5:44 pm
    sigmasix wrote:Modul8 has a virtual stage that has a preview size of 640x480 bananas… If your media is too big, it will be croped but you can scale it down and once you go fullscreen it will get all its pixels back. The scaling down operation is a difficult one actually, sometimes the "normalize" button doesn't produce what you would expect…
    thanks. i wasn't sure about my rendering size.
    OS X 10.9.1
    Mac Pro Early 2009
    OS X 10.9.1
Users browsing this forum: No registered users and 266 guests
