OSX Mavericks problems
  • illuminati
    by illuminati » Thu Oct 31, 2013 7:08 am
    For some reason i downloaded OSX Mavericks and installed it. :oops:
    Now when I use MM it is Full-screening only to the laptop screen.
    To make things worse (and most likely the cause of the problem ) the secondary monitor now has a status bar that stays visible when full screened (in Grand VJ) I found that when i used the Force resolution setting in GVJ that this made the status bar go away. but in MM its is still sending Fullscreen to laptop monitor.
    And yes... i have checked the projector settings already,and set to the external monitor output.
    Thanks in advance
  • illuminati
    Re: OSX Mavericks problems
    by illuminati » Thu Oct 31, 2013 8:15 am
    Found Fix posted in the Modul8 Support threads.
    Seems to work fine now.
    Re: Does Modul8 work with Mac OS 10.9?
    Postby JJHP3 » Thu Oct 24, 2013 5:17 am
    From Isadora forum:
    Go to System Preferences > Mission Control > You need to turn “Displays have separate Spaces” OFF and then restart machine.
    Works here - John
    by ilan » Mon Nov 11, 2013 2:10 pm
    For me MadMapper crashes on Mavericks. From what I can see it mostly has to do with revisions to QuickTime, which have been devastating. I recommend not installing Mavericks if you need to use MadMapper.
    The problem effects all versions of MadMapper.
  • eretron
    by eretron » Thu Dec 12, 2013 1:02 am
    Same thing here, had to go back to Mountain Lion.
    Any updates out there?
  • jeanpoole
    by jeanpoole » Tue Feb 04, 2014 8:42 am
    Eek!
    Have just started process of transferring workflow to a new mavericks based laptop - haven't come across any crashes yet though.
    I did notice that the 1.6.0 beta doesn't auto-recognise my syphon input ( from VDMX) ... (and I can't get it to appear at all )
    whereas 1.5.3 and others always showed it straight away...
    not sure if that's a 1.6.0 on mavericks issue, or a problem for 1.6.0 generally?
    anyways, thanks for the update...
  • visioncystem
    by visioncystem » Thu Jul 17, 2014 2:47 am
    I am experiencing the same problem as stated in the initial thread... I am running Mavericks on the new mac pro (black trash can). When I drag the output mad mapper window from my monitor to the projector display - the outputted video disappears immediately and when I hit fullscreen the output of MM is full screened on my monitor. Projector display is blank. I can't go back to mountain lion. This is rather horrifying. Is there a solve for this problem?
    Thanks,
    Philip
    Lytekode
    Roland V-Drums to Ableton to Modul8 Madmapper M4L
    Light Machine Time Explosions
    Contact <:>
