HAP Alpha looping problem
    Roger
    by Roger » Fri Nov 08, 2013 1:45 pm
    I'm trying some HAP Alpha loops with Modul8 2.8 alpha, it's a huge improvement on the compositing quality!
    But looks like there's a problem on the looping, every time a HAP alpha movie loops, it loses a few frames, gives a very bad impression.
    Anybody getting this problem as well?
  • te-c
    Re: HAP Alpha looping problem
    by te-c » Fri Nov 08, 2013 8:07 pm
    Did you use the new HAP 2 from the modul8 Blog?
    Roger
    by Roger » Sun Nov 10, 2013 3:55 pm
    Just tried HAP 2, same problem, even after re-encoding the file.
    david
    by david » Mon Nov 25, 2013 6:44 pm
    Hello Roger,
    have you reported your problem to support [at] garagecube [dot] com ?
    How many media are you using ?
    Which sizes/resolution ?
    What is your Mac model and graphics card ?
    Regards.
    Roger
    by Roger » Mon Nov 25, 2013 8:55 pm
    Hello David,
    Just one HAP-A media, 2048 x 2048, with the testcard underneath to test alpha.
    The playback is ok, but when it reaches the end, it stalls and loses the first frames.
    My specs:
    MacBook Pro 17-inch, Late 2011
    Processor 2.4 GHz Intel Core i7
    Memory 8 GB 1333 MHz DDR3
    Graphics AMD Radeon HD 6770M 1024 MB
    Software OS X 10.8.5 (12F45)
    I have not reported by email, do you want me to?
    david
    by david » Mon Nov 25, 2013 9:09 pm
    Please report, it will be easier to track the exchange and our support team is not always monitoring this forum.
    This forum is more intented for "inter-user support". For "official" support, please use our email.
    Regards
Users browsing this forum: Baidu [Spider] and 17 guests
