Transfer Madmapper lincese
  • GoncaloPires
    by GoncaloPires » Sun Nov 10, 2013 6:54 pm
    Hello all, my old MacBook Pro is dead. I've bought a new one and want to transfer the mad mapper lincense to authorize it on my new Mac.
    The other license is already activated on my IMac.
    I've already taken the Hard Drive from my old Mac in case any file of authorization is needed.
    Can anybody help me?!
    Thanks in advance
    Cheers from Portugal
    aktion
    Re: Transfer Madmapper lincese
    by aktion » Sun Nov 10, 2013 10:43 pm
    You can use something like Dynex 2.5" SATA Hard Drive Enclosure for your hard drive connect it to your new macbook via usb press the Option key at start up and boot up from your old operating system.
    once you in then simply unauthorize the license.
    The enclosure will help you transfer data too.
    Or email support and "MAYBE" they might be able to do it for you but i am not sure on that.
    Hope that helps
    AKTION STUDIO
  • GoncaloPires
    by GoncaloPires » Tue Nov 12, 2013 3:45 am
    Thanks a lot!
    Will try it today.
    by franz » Tue Nov 12, 2013 6:09 pm
    if it doesn't work, contact support[at]garagecube.com
    they'll help you
  • GoncaloPires
    by GoncaloPires » Thu Nov 28, 2013 10:17 pm
    aktion!
    It didn't work but i've already sent an email as Franz advised me. Hopefully they'll take care of my problem.
    Greetings
    aktion
    by aktion » Fri Nov 29, 2013 8:26 pm
    Hmm strange i did it like that once .. but good it will get sorted out the support team is excellent ..
    AKTION STUDIO
