File dialog screwed systemwide on Mavericks
  • Janson
    by Janson » Sun Nov 17, 2013 7:42 pm
    I have a strange problem on OSX Mavericks with Madmapper.
    A lot of my applications completely crash when they try to open a file dialog. The dialog appears, but after the first click somewhere, the application completely freezes. Applications for example are: Google Chrome, Firefox, Adobe Photoshop CS6.
    I finally think this is somehow a madmapper issue, because when the problem appears, on the console I noticed a flood of messages like this:
    Adobe Photoshop CS6[4066]: Warning: Cache image returned by the server has size range covering all valid image sizes. Binding: BundleBinding [0x3d03] URL: file://localhost/Applications/MadMapper.app/ bundle identifier: com.garagecube.MadMapper request size:512 scale: 2
    And then these messages once:
    WindowServer[118]: disable_update_timeout: UI updates were forcibly disabled by application "Photoshop" for over 1.00 seconds. Server has re-enabled them.
    WindowServer[118]: disable_update_likely_unbalanced: UI updates still disabled by application "Photoshop" after 15.00 seconds (server forcibly re-enabled them after 1.00 seconds). Likely an unbalanced disableUpdate call.
    Madmapper itself seems to work fine.
    Any ideas? Should I try to reinstall Madmapper?
  • Janson
    Re: File dialog screwed systemwide on Mavericks
    by Janson » Mon Nov 25, 2013 7:19 pm
    Ok, it turned out to be a finder issue not related to MadMapper. Deleting the finder preference file fixed the issue.
