Mapping "Transform/Patch (thickness, div x, div y)"
    johncgaiser
    by johncgaiser » Tue Nov 19, 2013 3:04 am
    I have noticed that everytime I attempt to map TRANSFORMER/PATCH/(thickness, div x, div y) the signal resets to "0"
    I tried to create a module that would control the (thickness, div x, div y) but results the same. Is there any solution to this?
    I would like to be able to use these parameters on a midi map as well as sound router and bpm router.
    Thanks.
    david
    Re: Mapping "Transform/Patch (thickness, div x, div y)"
    by david » Mon Nov 25, 2013 6:25 pm
    Hello johncgaiser,
    could you contact support [at] garagecube [dot] com, we have a modified Modul8 2.7.1 version that corrects the midi mapping problem of thickness/divx/divy.
    Regards
