MadMapper 1.6 beta 1 released
    by franz » Wed Nov 20, 2013 4:48 pm
    today we're happy to release MadMapper version 1.6 beta 1.
    What's new in this version:
    - built in Midi/DMX/Keyboard inputs, assignable to any MadMapper parameters.
    This was a long-awaited feature, requested by many users.
    It includes support for 14-bit midi, with feedback.
    We also added the ability to filter incoming values. With this system, it is very easy to assign shortcut keys to dynamically fade in / fade out surfaces' opacity.
    We designed a special control window to handle all shortcuts/affectations at once. You can even access some parameters not directly present in the interface, such as a surface' X/Y position.
    - new DMX/Lighting system, which includes:
    - Artnet Unicast support, fully remappable, per-IP options
    - new DMX panel in the UI
    - redesigned fixture editor, fully customisable
    - manual channels re-ordering
    - custom DMX channels in any order
    - expressions in DMX channels ( now you can type channel_1 = R + G/2 for instance)
    - user defined DMX sliders
    - built-in DMX monitor
    - surfaces selections optimizations
    - selection booleans (Shift to add to selection, Alt to remove)
    - numerous bugfixes and optimizations
    Please do not use this beta in production.
    Report us whatever bugs you find, we'll make the next release better.
    Download as usual from http://www.madmapper.com/yourspace
    Enjoy.
    GarageCube and 1024 Architecture teams.
    shveddi
    Midi controll
    by shveddi » Fri Dec 13, 2013 9:53 am
    Good afternoon.
    I want to add midi position X, Y, size, and rotation for the two windows. For incoming and outgoing images. Let's say I'm trying to bind to the Wii constantly moving objects. He wants to watch him and moved. At the moment I can only change the parameters of the incoming picture.
    Sincerely Sergei.
  • tony_blend
    Re: MadMapper 1.6 beta 1 released
    by tony_blend » Mon Jan 20, 2014 1:02 am
    Whats new in Beta2 ?
    Fragmentia: A relatively new cognitive disorder where one feels cut off from a sense of wholeness because of constant exposure to only incomplete parts of things and ideas which do not
    by franz » Mon Jan 20, 2014 3:26 am
    bug fixes + OSC
    beta 3 should be coming this week
Users browsing this forum: No registered users and 57 guests
