Madmapper and Enttec DMX USB Bug (disconnect)
  • chromaphase
    by chromaphase » Sun Dec 01, 2013 4:59 pm
    First thanks for this awesome software ;)
    Im Chromaphase, Im based in Shanghai, China.
    I made my first show last week.
    Sometimes, I have a bug, its like the DMX Usb disconnect by itself, seems completly random, sometime bug after 1min, sometimes after 30min.
    I need to go to preferences, then select none, then reselect usb dmx, and it works again.
    It was with the 1.5.1, I just saw you have updated to 1.5.3 and installed it, but right now cant test it.
    It is this kind of bug you have fixed with the 1.5.2 already ?
    Or as Im in china, I use a Enttec dmx usb that is not good. But when i did some 2hours test with it 1 month before my show, it didnt bug.
    During my show I use resolume external mic to give the tempo to my LED, so maybe it makes it bug. I dont really know ;)
    Thank you!
    Chromaphase
    Re: Madmapper and Enttec DMX USB Bug (disconnect)
    by mad-matt » Mon Jan 06, 2014 1:24 pm
    This new build should solve your issue. It is still a beta but should be release soon: https://www.dropbox.com/s/gut74lkosn2a1 ... 1_BETA.dmg
    Enttec DMX has been rewritten. It can now be disconnected and reconnected while the application is running.
    Regards,
    Matthieu - MM team
Users browsing this forum: Baidu [Spider] and 30 guests
