MadLight Unicast
  • kjell
    MadLight Unicast
    by kjell » Fri Dec 06, 2013 3:16 pm
    Hey Guys,
    i dint understand the unicast function for art net,
    usualy i should be able to set an address where the data is join,
    but i cannot find it ?
    we have a art net network with a chamsys, a hog, 4 artnet nods an so on, so broadcast will f.... up the whole system,
    i just want the data to be send to the chamsys, not the rest of the stuff...
    any ideas ?
    greetings from the Maplab,
    kjell
  • Janson
    Re: MadLight Unicast
    by Janson » Sat Dec 07, 2013 4:47 pm
    It only works if your ArtNet nodes support ArtNet Polling. So the correct addresses will be discovered automatically.
    If you want to edit the addresses manually you have to use Madmapper 1.6 Beta or wait for the next releases.
  • kjell
    by kjell » Sun Dec 08, 2013 9:36 pm
    okay,
    Good to know :)
    Thanks dir the fast answer!
