Gener8
  • gigi.antani
    Gener8
    by gigi.antani » Wed Dec 11, 2013 5:54 pm
    Hi, i've a lot of problem with Gener8 and i did'n find any informations about it.
    First question: it's normal that my new novation launchpad s doesn't light its buttons when i press them? (in ableton live i tested the device, it works)
    second: when i configure the module (launchpad) the first column of the module is linked to the second column on the launchpad.
    Tks
    ghostofelvis100
    Re: Gener8
    by ghostofelvis100 » Thu Dec 12, 2013 3:07 am
    Hi Gigi,
    I'm waiting for a response from Novation on this one now, but it would be really useful to see a midi message from the 'launchpad s' so I can sort this out.
    If you can open up the Direct Event module, enable 'midi', and hit some launchpad keys, then mail me back a screen shot?
    Andy T.
  • sir.phit
    Re: Gener8
    by sir.phit » Thu Mar 10, 2016 12:40 am
    the lights themselves are a different cc value, so one would need to add the cc value equal to the lights on it to make them set off(or on)
    couple years late to the quarry i know however that is the problem, u need to add in the values for the lights if you want them to work.
    ghostofelvis100
    Re: Gener8
    by ghostofelvis100 » Thu Mar 10, 2016 12:50 am
    As far as I know, both Launchpad models have the same cc numbers, only there is a different midi device name, which I implemented into the module sometime ago. I've still not seen it working with my own eyes though so cannot verify, but I've been told it works.
    I will double check about the cc's though. Thanks for the update. :D
  • sir.phit
    Re: Gener8
    by sir.phit » Thu Mar 10, 2016 1:14 am
    have you peeped this midi value cheat sheet out? page 3 is lights and their values ;) https://d19ulaff0trnck.cloudfront.net/s ... erence.pdf
    ghostofelvis100
    Re: Gener8
    by ghostofelvis100 » Thu Mar 10, 2016 1:23 am
    Yes, I had just double checked.
    They are identical. The difference was how modul8 recognises each device.
    Do you run a launchpad with Gener8/Modul8 yourself?
    launchpad s.tiff
    Launchpad s
    launchpad s.tiff (150.93 KiB) Viewed 23202 times
    launchpad.tiff
    Original Launchpad
    launchpad.tiff (206.67 KiB) Viewed 23202 times
  • sir.phit
    Re: Gener8
    by sir.phit » Thu Mar 10, 2016 9:44 pm
    i do not have a launch pad but i do remember how much this same issue bothered me with a different controller i have in my collection and there for thought i should chime in and help fix it if possible, sadly we have the same problem caused by a different issue(my controllers lights had different cc values then the controls themselves thusly i had to create two notations off one button press)
    really was hoping i could help solve this old problem.
