About LED strips
  • kinksid
    About LED strips
    by kinksid » Sun Dec 29, 2013 9:29 pm
    single color (3825) - L
    RGB 3 colors (5050) - RBG
    I tested already
    but when i use the IC6803, dont have Slider effect
    how to simulate shooting star, i mean, from first led to end
    second,as MM dont support 2 universe, i wonder if series connection another DMX dimmer availabe???
    let me know plz...
    info@sueno.asia
    NateMac
    Re: About LED strips
    by NateMac » Mon Dec 30, 2013 7:38 pm
    Are your LEDs chipped? (i.e. WS2811, WS2801, ect) It doesn't sound like they are. Your strip wire connections should be PWR,DATA,GROUND or PWR,DATA,CLOCK,GROUND.
    MM does support Multiple Universes.
    aktion
    by aktion » Tue Dec 31, 2013 1:05 am
    Hey Nat,
    If so .. I mean if lets say i have addressable Leds whats the process then ..
    AKTION STUDIO
    NateMac
    by NateMac » Tue Dec 31, 2013 5:00 pm
    Hey Nat,
    Do a search here and you'll find a lot of information on DMX Decoders & Encoders.
    If you want something supported by GarageCube & 1024, look at the Enttec devices with a DMX Decoder.
    I've been more interested in the Arduino method that combines the Encoder and Decoder into one device, but not to much support out there for it.
  • kinksid
    by kinksid » Tue Jan 14, 2014 8:42 pm
    LED strips: http://trade.taobao.com/trade/detail/tr ... 9455993191
    BUT!!!!! didnt have the shoot star effect.Image
    DIMMER: http://item.taobao.com/item.htm?id=26194728910
    i want use its out to another input. havnt tested
    any strips can do shoot star effect via PWR,DATA,GROUND
  • kinksid
    by kinksid » Tue Jan 14, 2014 8:46 pm
    Hey Nat,
    If u want a expended way -choose Arduino
  • axistudio
    by axistudio » Thu Apr 10, 2014 7:05 pm
    I am using chipped Led strip with the name of WS2811 and WS2801, i am using exactly same dmx decoder as the one you use. Only the enttec converter is a similar fake one that made in china.http://item.taobao.com/item.htm?spm=a1z ... mm3h5ff6fd
    when i connect whole things together, still no any positive result. i could only light up the WS2801 for only one time with only the red light on the strip. help me please!
  • Xaver2k
    by Xaver2k » Fri Apr 11, 2014 8:28 am
    @kinksid
    the led strip looks like the digital ones, are you trying to use a digital leds strip with that controller?
    if yes it could never work....
    @axistudio
    chipped leds are also called digital leds strips....
    you can´t control them with this kind of controller because its only a dimmer for regular leds strips!
