Memory leak with USB DMX Pro?
  • benpurdy
    by benpurdy » Sun Jan 05, 2014 11:07 am
    I've tried both an enttec DMX USB Pro, and the Mk2, when using either one the memory and CPU utilization of madmapper slowly climb. As soon as I set the DMX Output setting to "none" the memory and CPU drop back to a normal, steady level. Selecting one of the Artnet options also gets rid of the problem, it only occurs with the USB devices.
    The memory climbs at about 1 MB every 10 seconds or so, CPU usage creeps up slower and is harder to measure since it tends to bounce around a little as it climbs.. After about 25 minutes the CPU usage is up to 63% and climbing, normally it sits around 20% at all times.
    Has anybody else experienced this? I'm nervous about using it for a long set when it appears to be leaking..
    My setup:
    late 2013 macbook pro running OS X 10.9 (13A3017)
    VDMX -> Madmapper via syphon
    Re: Memory leak with USB DMX Pro?
    by franz » Mon Jan 06, 2014 12:06 pm
    what version of mad mapper are you using ?
    by mad-matt » Mon Jan 06, 2014 1:19 pm
    Hi Ben,
    That issue has been fixed in 1.6. You can use the beta version here: https://www.dropbox.com/s/gut74lkosn2a1 ... 1_BETA.dmg
    Let us know if you have any issue.
    Matthieu - MM team
