Madlight with Enttec DMXIS?
  • stevesavage
    by stevesavage » Sat Feb 08, 2014 4:26 pm
    Has anybody had experience with using the Enttec DMXIS with madlight, as opposed to the normal Enttec open or pro?
    Does it work, or should I just go with the pro for the best means of controlling ledstrips?
    Thanks
    Steve
    Re: Madlight with Enttec DMXIS?
    by franz » Mon Feb 10, 2014 11:04 am
    I would recommend the Artnet Enttec ODE. It uses the ethernet port instead of the USB port.
  • mbirame
    by mbirame » Sun Dec 20, 2015 7:06 am
    Hi-I'm already using the ethernet port on my laptop to receive midi signals from another computer. I also have DMXIS, but it is being used to control the regular stage LEDs. Is it possible to control both those lights and use MadLight at the same time?
