cant script a fade out
  • Raz___
    by Raz___ » Sat Feb 15, 2014 6:23 am
    So basically in my MessageEvent() I have it select a video based on text input(this part works fine) but then I want it to fade out at the end(or at the very least stay up for a set time then cut out) here is what I have
    import time
    #selects video, this part works
    time.sleep(7)
    opac = 0.0 #this stands for opacity
    for i in range(0, 10):
    time.sleep(.1)
    modul8.setValue('ctrl_layer_alpha, opac, 1)
    opac -= .1
    the problem I am running into is it does not effect anything on the screen until the entire script has finished running, so that after the message call it waits about 8 seconds then displays a completely faded layer never showing what I want. I would be happy with just playing the video and then a hard cut after the length of time, but it wont do that.
    Does anyone know whats wrong with my code or can think of another way of doing this?
  • anomad
    Re: cant script a fade out
    by anomad » Sat Feb 15, 2014 7:45 pm
    . iirc, the modul8 engine is deterministic (so everything runs as fast as it can, whenever it can... anyone feel free to correct me on this )
    . for time based items, i use PeriodicalEvent()
    . so, in Init() declare a variable, ie,
    Code: Select all
    fadeOutConter = 1.0
    . in PeriodicalEvent() have some code similar to
    Code: Select all
    if fadeOutCounter > 0 : fadeOutCounter -= 0.05 ## change this number to speed up/slow down how fast things happen modul8.setValue('ctrl_layer_alpha, fadeOutCounter, 1)
    . then, in MessageEvent, whenever the button is clicked (or whatever), reset fadeOutCounter to equal 1.0
    . hope that helps :)
    -james
    (a nomad. )
  • Raz___
    by Raz___ » Mon Feb 17, 2014 4:42 am
    Great wonderful that worked perfectly thank you so much, I had started to get really worried that I would never be able to finish this installation.
