Sequence Presets
  • Bitpix
    Sequence Presets
    by Bitpix » Thu Feb 20, 2014 11:51 pm
    Hey guys, is there a possibility to Seuence the Presets?
    Thx a lot
    BitPix
    Re: Sequence Presets
    by franz » Fri Feb 21, 2014 10:17 am
    Yep, you can use an external sequencer with MM 1.6:
    - Ableton Live (sending Midi)
    - Vezer (Midi or OSC)
    - Duration (free, OSC)
    or any hardware sequencer using Midi, or you can build your own using Quartz Composer, MaxMsp , Pure Data ... etc.
Users browsing this forum: Baidu [Spider] and 33 guests
