How to send Madmapper's output to Syphon ?
  • allexandre
    by allexandre » Tue Feb 25, 2014 3:07 pm
    I would like to send the Madmapper's output to Syphon. My aim is to record the mapping processing in Syphon Recorder. It is possible ? if not, what is the solution to record the Madmapper's output.
    More precisely, my currently setup is :
    1/ Video generation in Jitter
    2/ Send to Madmapper with Syphon (and jit.gl.syphonsever) to mapping processing (that I want to record in Syphon recorder)
    Best regards
    Alex
    Re: How to send Madmapper's output to Syphon ?
    by franz » Wed Feb 26, 2014 10:57 am
    enable syphon output in the Preferences
  • allexandre
    by allexandre » Wed Feb 26, 2014 6:12 pm
    Thank you for your answer.
    Syphon is enable in Preferences (screen capture 1).
    However, I don't understand how to send the video signal in Syphon recorder ? (screen capture 2)
    Madmapper Preferences
    Capture d’écran 2014-02-26 à 17.07.24.png (50.38 KiB) Viewed 9225 times
    Madmapper output
    Capture d’écran 2014-02-26 à 17.07.34.png (29.73 KiB) Viewed 9225 times
    Best regards.
    Alex
    PS : I use Madmapper 1.5.3 beta (Demo).
  • allexandre
    by allexandre » Thu Feb 27, 2014 11:47 pm
    Today, that work.
    Thank you again
    Alex
