Advice - Getting a mac for video mapping
  • Avengerxp
    by Avengerxp » Sun Mar 02, 2014 6:25 am
    I am planning to buy a mac for video mapping and I will be using mad mapper and module 8. I am looking at a macbook pro and a bit confused about the graphic requirements of mad mapper.
    The current macbook pros have iris graphics and also iris graphics plus nvidia graphics. I am planning for the core i7 version and the RAM 8GB. please advice which I should buy to get a smooth performance in video mapping.
    and also 2 thunderbolt ports will support 2 out puts plus the macbook pros monitor as the control?
    thanks you and am sorry if this hasbeen asked before.
    Re: Advice - Getting a mac for video mapping
    by franz » Sun Mar 02, 2014 5:56 pm
    nvidia graphics. don't buy iris only, that's not good for visuals.
    get a SSD + min 8gb Ram.
    ideally, the most expensive mac is the most powerful.
    NateMac
    by NateMac » Sun Mar 02, 2014 9:34 pm
    All MacBook pros can handle 2 external display up to 2560x1440
    All have PCI-SSDs
    All come with at least 8gb or ram
    I've run MM on a 09 MacBook Pro, which isn't even close to even the Iris graphics or the i series processors.
    If you can afford the top of the line, it won't hurt, but it also won't hinder running on something a little slower.
    Think long term, is it better to go all out now and create an investment computer or start a little lower and go bigger later, for instance a 2013 Mac Pro in a pelican case that has dual workstation cards and 24 thread processor... Just sayin' 8)
  • Avengerxp
    by Avengerxp » Mon Mar 03, 2014 6:12 am
    Thanks a lot for the feedback. I am looking for something mobile. so it's going to be a macbook pro. and as I'm buying this for our Studio, i would go big now i guess. Thanks a lot! :D
    NateMac
    by NateMac » Mon Mar 03, 2014 4:56 pm
    Then the MacBook Pro is the way to go.
    We have dual Mac Pro's in travel rollers so sometime I forget what's portable to some is not to other haha.
    Our 2013 Mac Pro was to come in February but Apple kinda dropped the ball on that, but we are seeing if we can turn or 200lb. rollers into a pelican case.
    Here's a great article to put into context how small such a powerful machine is. That we could stuff one of these and a 24" monitor into a case and walk on a plane.
    12 things that show how small the Mac Pro really is
  • tony_blend
    by tony_blend » Tue Mar 04, 2014 1:17 am
    The new MacBook Pros can run 3 displays out the box. 2 x DP and 1 x HDMI with no problems.
    Fragmentia: A relatively new cognitive disorder where one feels cut off from a sense of wholeness because of constant exposure to only incomplete parts of things and ideas which do not
    NateMac
    by NateMac » Tue Mar 04, 2014 2:35 am
    Are you sure on 3, I'm getting mixed information online, but as far as apples own site says
    Dual display and video mirroring: Simultaneously supports full native resolution on the built-in display and up to 2560 by 1600 pixels on up to two external displays, both at millions of colors
    deepvisual
    by deepvisual » Wed Mar 05, 2014 12:06 pm
    my retina MBP has two thunderbolt outs and one HDMI = 3 outputs.
    NateMac
    by NateMac » Wed Mar 05, 2014 10:09 pm
    You could actually daisy-chain two thunderbolt displays on a single thunderbolt port, that doesn't mean it can run 5 displays now.
    Just because you have three port's doesn't mean you can run three displays.
    But if you can, running three 1080p signals and a 2880x1440 screen, might really tax the GPUs memory and other problems might allude themselves.
    deepvisual
    by deepvisual » Thu Mar 06, 2014 12:23 pm
    we got 4 x 720p using a datapath X4 from a retina MBP.
  • Avengerxp
    by Avengerxp » Fri Mar 07, 2014 3:36 am
    Thanks a lot for the informative conversation going on here. I too checked and have noted 2 thunderbolt outs. for the start I will be using just one out with a matrox trplehead2go unit for large outdoor projections. can you guys point me to a good resource to get the basics of edge blending with modul8.
    thanks a lot for the link.
