Locked 7 posts Page 1 of 1
grouping surfaces?
  • bc-mich
    grouping surfaces?
    by bc-mich » Fri Mar 07, 2014 1:19 am
    How can I 'group' surfaces?
    I have about 10 of 20 surfaces I would like to manipulate as a whole, for starters just move them all together. I can highlight easily by various means, but once I 'click' and try to drag, it highlights that specific individual surface... in any screen I try. Is there a way to 'lock' a group? Scaling and other simple functions would be good to achieve too.
    Re: grouping surfaces?
    by franz » Sun Mar 09, 2014 9:13 pm
    grouping is in the tube
  • bc-mich
    by bc-mich » Thu Mar 20, 2014 2:18 am
    Thanks for the response Franz,
    but, pardon my inexperience, what/ where is 'the tube' ?
  • Xaver2k
    by Xaver2k » Thu Mar 20, 2014 9:05 pm
    i think he meens the field on the top right
  • bc-mich
    by bc-mich » Fri Mar 21, 2014 2:53 am
    thanks Xaver2k
    ok, so this is the best I can do:
    1-highlight surfaces to be grouped
    2-go to the box in the top right corner and enter a name (ie. bottom screens), hit 'return'
    3-un-click selection of surfaces
    4-go back to the box top right, find 'bottom screens' in pull-down menu, click on it
    5-selection is now grouped, I am able to move as a group
    Next question: I would like to do is basic transformations to the entire selection, scale/rotate. Is this possible?
    by sigmasix » Fri Mar 21, 2014 10:40 am
    in the tube meant it's in the process of being implemented… You can group selections but you cannot rotate, skew or scale in a grouped manner yet
  • bc-mich
    by bc-mich » Fri Mar 21, 2014 6:47 pm
    I am really looking forward to those functions becoming available. I will be patient as they 'come down the pipe'.
