Send a video signal to another laptop with Modul8?
  • AgentD
    by AgentD » Thu Mar 13, 2014 5:53 pm
    I have two MacbookPros with Modul8 installed and one of them is connected to a projector. I want to send a video out to this laptop as "Video Input" to be able to mix. (So the idea is kind of like use the first laptop as a video mixer.)
    Is there any way that I can achieve this via for example connect two computers with Firewire? I normally use a V-4 mixer which I connect two laptops with scan coverters but I might not be able to get the S-video or Composite connection from the projector so I am trying to come up with a solution.
    Please let me know if you have any experiences with this issue or have any suggestions. Thank you in advance!
    AgentD
  • tony_blend
    Re: Send a video signal to another laptop with Modul8?
    by tony_blend » Fri Mar 14, 2014 3:29 pm
    Syphon2network works well as long as you keep your screen size to a normal OSX one (640x480 / 1024x768 etc).
    http://www.vjkidkadian.com/store
    Make sure to change the port from the default one though.
    Fragmentia: A relatively new cognitive disorder where one feels cut off from a sense of wholeness because of constant exposure to only incomplete parts of things and ideas which do not
