AppleTV
    sehrinde17
    AppleTV
    by sehrinde17 » Tue Mar 18, 2014 7:57 pm
    hello and moin moin!
    Some setups of me need no "active" live performance. Simple Stand alone- maybe sometimes a few changes.
    So i had the idea to use an appleTV to send the video to an hdmi projector- wirelessly! I tested it with an ipad and the integrated video stream of IOS 7. I´m impressed of the well framerate in apple´s Airdisplay. Exact what i need- no cables more for a simple standalone projection with minimal access to some parameters.
    But now the question: How can I send an modul8 scene tom an mac via WLAN to the beamer/ appleTV? Do i need a custom software to have the benefits of AirDisplay?
    I´m very happy for any kind of help!
    MacBook Pro Retina, Mid 2012
    2,3 GHz Intel i7 | 8 GB Ram | NVIDIA GeForce GT 650M 1024 MB | 250 GB SSD
    OS X 10.9.1
    Mac Pro Early 2009
    2x 2,26 GHz Intel Xeon | 24 GB Ram | NVIDIA GeForce GT 120 512 MB | 2x 2 TB SATA
    OS X 10.9.1
    Re: AppleTV
    by sigmasix » Thu Mar 20, 2014 2:35 pm
    since mountain lion you have your available air displays in your system menu bar. Then you'll have your screen mirrored to your apple tv.
    sehrinde17
    Re: AppleTV
    by sehrinde17 » Sat Mar 29, 2014 3:41 pm
    Yes. I've tested it. With the build-in feature in Mavericks it´s very easy to select (only) one AppleTv in MadMapper as the Outputmonitor. G_R_E_A_T
    OS X 10.9.1
    Mac Pro Early 2009
    OS X 10.9.1
  • diz_co
    Re: AppleTV
    by diz_co » Thu Nov 27, 2014 5:16 pm
    Can someone detail a work-thro for using an apple TV device please. I'm still on Mountain Lion. Do i need to upgrade?
  • Kerena104
    Re: AppleTV
    by Kerena104 » Fri Jan 09, 2015 5:22 pm
    Yes, upgrading your software can help.
    Kerena
  • Plastic
    Re: AppleTV
    by Plastic » Mon Feb 23, 2015 1:06 pm
    Yep it worked in my case so try that:)
