Projection simulation
  • Xaver2k
    by Xaver2k » Mon Mar 24, 2014 2:33 pm
    Hey guys i´m looking for a software to simulate some Projection mapping,
    i thought madmapper could recognize it as a virtual Projector and in the software i can build up the stage and some fixtures to map them.
    Anyone has some good suggestions?
    Thanks
    Re: Projection simulation
    by franz » Tue Mar 25, 2014 4:17 pm
    mad mapper can simulate.
    Just load a photo - or a 3d rendering, or a space scan - in your projector background and you're good to go.
  • Xaver2k
    by Xaver2k » Tue Mar 25, 2014 6:54 pm
    hmm good idea, will try it Thanks! 8)
    but i mean more a real simulation like building a 3d room in cad and putting some projectors in it also for better planing where to put the projectors?
    by franz » Wed Mar 26, 2014 1:12 pm
    use 3dsmax then
    placing projectors is simple, it's a mean between:
    - where you CAN place them
    - where you cover your wanted surface as much as possible
    - where you have the less deformation in your projected image
  • Xaver2k
    by Xaver2k » Wed Mar 26, 2014 2:21 pm
    ok still nothing out there for what i´m looking for, Thanks :(
  • najrock
    by najrock » Tue Apr 22, 2014 3:27 pm
    you can use Touchdesigner, D3, AI or pandora...
    Touchdesigner is free for non commercial use and is much deeper than just a previz... it is PC only and learning curve is steep... for that reason it is not optimum for many situations... but it can handle the more difficult ones with ease.
  • Xaver2k
    by Xaver2k » Fri Apr 25, 2014 11:25 am
    will take a look for it thank you!
    by sigmasix » Fri Apr 25, 2014 2:16 pm
    I know you can simulate a video projector with Capture Polar (http://www.capturesweden.com) but didn't look at it deeply and I don't know if it does what you expect
