Automate sequence presets?
  • whagan
    by whagan » Thu Mar 27, 2014 1:28 am
    What would be the best way to get Madmapper to automatically run through defined presets? Is it possible in it's current incarnation?
    Thanks, Wayne
  • Xaver2k
    Re: Automate sequence presets?
    by Xaver2k » Thu Mar 27, 2014 9:48 am
    you can do it with midi commands.
    what setup do you have?
  • whagan
    by whagan » Thu Mar 27, 2014 6:17 pm
    I'm running Mapmapper 1.5.3 on a Macbook Pro, I tried running the 1.6 Beta but it crashes immediately on boot. I have activated the MIDI menu via Terminal but have yet to dip my toe in MIDI as from what I read on the blog it might not yet be ready for prime time. Im trying to run a demo at my company where MM would automatically run through the presets unattended (loop).
    Thanks for the input!
    -Wayne
  • .lov._
    by .lov._ » Fri Mar 28, 2014 7:28 am
    You could do that by using Vezér (www.vezerapp.hu) with MadMapper (1.6b) via OSC. Of course, if the 1.6b crashes for you its not the case, but I suggest to let the developers know about the crashing issue.
    Vezér - timeline and control software for visual artists
    by franz » Sun Mar 30, 2014 7:44 pm
    pleaae contact the support they'll help you with the crash
Users browsing this forum: Baidu [Spider] and 21 guests
