Madlight and LPD8806 LEDs
  • CliveWr
    by CliveWr » Fri Apr 04, 2014 1:56 pm
    Does Madmapper natively support individually addressing LPD8806 LEDs?
    I can't find a way to do this.
    I've seen it done with an Arduino but I've also seen on the forums people saying that you don't need one.
    Should I be using WS2811 LEDs instead?
    Thanks in advance! :)
  • Xaver2k
    Re: Madlight and LPD8806 LEDs
    by Xaver2k » Sat Apr 05, 2014 11:48 pm
    you will need a controller...
    you can send the data from madmapper via dmx or artnet to a controller, like arduino, and the controller will control the leds.
  • CliveWr
    by CliveWr » Sun Apr 06, 2014 12:17 am
    I currently use an Enttec ODE with regular 5050 LEDs through a controller board however I can't seem to figure out how to work them.
    The board takes in LEDs, R,G,B,+
    and the LPD8806's go Ground, Digital, Control, +5v.
    Any guidance?
    Thanks
  • Xaver2k
    by Xaver2k » Sun Apr 06, 2014 12:22 pm
    just google for it first! it would be easier for all of us.
    i only put "lpd8806 arduino" and the first result was https://github.com/adafruit/LPD8806
    so put in some microcontroller or any other type of controller
  • CliveWr
    by CliveWr » Sun Apr 06, 2014 8:35 pm
    Don't be so touchy...
    The reason for a forum is for people to come together and support each other.
    I am fully capable of controlling LEDs through an Arduino.
    All I was asking for was if it was possible through a DMX controlled LED dimmer.
    You obviously can't help. Maybe someone else can.
  • Xaver2k
    by Xaver2k » Sun Apr 06, 2014 10:23 pm
    oh sorry for being so touchy,
    maybe i understand your question wrong,
    no you can not control digital led strips with a DMX controlled LED dimmer.
    With DMX controlled LED dimmer you can control only the regular mulitcolor (RGB) or one color strips... you just have to take a look for the voltage of the strip.
    to control these with madmapper you need a DMX-USB or DMX-Artnet interface.
    To control digital led strips like the WS2812 or the LPD8806 you will an micro-/ controler.
    to control these with madmapper you need to implement the DMX-USB or the DMX-Artnet function or you buy one
