Multiple surface size increase/decrease
  • marcindo
    by marcindo » Tue Apr 15, 2014 8:15 pm
    I am using Mad mapper and have a query that I hope you can answer.
    When you click on a surface you can see the rotation and size (increase/decrease) circle tabs in blue. I would like to know if it is possible to select multiple surfaces and increase the size and decrease the sizes of the objects together using the blue tab to keep everything selected in place without having to do it individually for each surface and reposition them after. Does this make sense?
    I have tried selecting multiple surfaces and using the blue tab but it only does it for the one blue tab you click on.
    Many thanks
    Marc
  • Xaver2k
    Re: Multiple surface size increase/decrease
    by Xaver2k » Wed Apr 16, 2014 8:07 am
    not possible at the moment, but they are working on it.
