App Crashing deletes project file contents
  • nicholasrivero
    by nicholasrivero » Tue Apr 15, 2014 9:41 pm
    Hello! I have been using MadMapper recently on some shows in conjunction with Resolume Avenue. In short, after creating a full map file and then tweaking the map into alignment, upon saving, it will randomly crash. But upon re-opening the same project file, the .mad file will now read a file size of "0 KB" and be completely void of anything I've done.
    The project is using a Retain Macbook Pro connected to 3 displays: Thunderbolt outputs 1 & 2 and the HDMI. All 3 are connected to HDMI to SDI converters.
    Outputs: 3 at 1920x1080.
    MadMapper canvas Size: 5760x1080
    MadMapper Version 1.5.3.2698
    Mac OS: 10.92.
    Model Mac: Retina MacBook Pro
    Processor: 2.6 Ghz Intel i&
    Ram: 16 GB
    Let me know if you have any questions or any thoughts!
    Re: App Crashing deletes project file contents
    by franz » Tue Apr 15, 2014 11:14 pm
    please contact the support
  • Xaver2k
    by Xaver2k » Wed Apr 16, 2014 8:17 am
    maybe, try to disable App nap could help.
